HP3421A Message #1 Posted by Jeff on 4 July 2005, 1:18 p.m.
Have acquired a used HP3421A (to replace an older unit that died), and am having difficulty getting this unit to measure at AC voltages below ~60mV. The prior unit had no problem before it went on us. Generally, once you input a voltage higher than this (give or take), it begins to read more accurately (it needs cal. as its a bit off, but ok for now). Any thoughts?
Thanks,
Jeff
