L() and G() functions on HP17BII+ Message #1 Posted by Christopher dean on 12 May 2005, 4:24 a.m.
I have tried the L and G functions on my HP17BII+ and I have found that the L function works okay but the G function does not.
If I use the equation L(A:X) + A - B = 0 and enter 3 for X and solve for B the result is 6.
If I use the equation L(X) + G(A) - B = 0 and enter 3 the result is 3.
The first equation does have the added pain of seeing the variable A on the Menu bar but seems to work.
Even more confusing if I use the first equation and calculate and then use the second equation and calculate the G function appears to work. If I then change the variable from A to Z, say, then calculate using the second equation it fails!!!! Is there some sort of memory problem?
