Re: Calc cleaning Message #2 Posted by Mike H on 11 May 2005, 5:29 p.m., in response to message #1 by Giancarlo
Hi Giancarlo,
The best cleaning solvent would be a very dilute solution of hydroxide and hydronium ions as follows:
2 H2O <=> H3O+(aq) + OH-(aq)
At room temperature, about 1 in every 10 000 000 molecules of this solvent has been dissociated by donating a hydrogen atom to another.
Hydroxide ion is the caustic component of lye, and hydronium ion makes acid solutions corrosive. However, the concentrations in this solution are extremely low and not at all dangerous.
Use caution however, because this solvent also reacts with atmospheric carbon dioxide which brings the pH of the solvent in an open-air container down to about 5.8.
Good luck
