Re: Need help - HP 17BII cleaning Message #4 Posted by MIke H on 16 Apr 2005, 11:21 p.m., in response to message #3 by Selim
Selim, it easy to open a pioneer calculator, however, you can not get to the keys just by opening the case. There are lots of threads in the archives about opening and cleaning keys. I would start by removing the batteries and dipping it into an ultrasonic cleaner. If you dont have one of those, I have used distilled water with good success. I drop the whole calculator under the water, press the keys and clean with a toothbrush. Shake it out, towl dry and then let it air dry for two days before I but the batteries back in. This method goes against common sense, but I have never had a problem with it.
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv014.cgi?read=69775
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv014.cgi?read=67188
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv014.cgi?read=55509
