Re: NiCad voltages Message #6 Posted by Randy on 10 Apr 2005, 11:37 p.m., in response to message #1 by Howard
Many conditionals apply to the following general statement: Ni-cads are considered to be fully charged when they reach approximately 1.35-1.4 vdc per cell. Not perfect for many reasons but a good place to begin discussions. 1.1 vdc is (generally) considered to be the bottom of the discharge curve, that is when it begins to fall like a rock.
Another (inaccurate) way to assume full charge is (cell capacity/charge rate) = time required. For example: an original 600 mah classic nicad pack requires 10 hours at the standard 82002 charger rate of 60ma. Change those to 1100mah cells and it *should* require ~18 hours to reach full charge. Extrapolate to suit.
