Re: Emu42PPC now available with VGA support Message #4 Posted by Christoph Giesselink on 31 Mar 2005, 5:34 p.m., in response to message #3 by Andre Koppel
This has nothing to do with WM 2003, I know at last five different devices with WM 2003 where Emu42/48 is running perfectly on. Finally my VGA device, a Dell Axim X50v, is running with WM 2003 SE.
The problem is that the devices are quite different, because any manufacturer can config the operating system in a wide range. Furthermore you can solve problems in applications by different ways, so there's no "must go" way. Because of that there can be incompatibilities between a Windows Mobile device and an application. Or just bugs, it's quite hard to detect memory access misalignments, sometimes the software crash immediately at the misalignment or never. Or a bug in the OS, that "Topbar 0" wasn't working properly under WM 2003 (SE) is a bug of OS not of the emulator. This bug was introduced in WM 2003, Pocket PC 2002 behave like expected.
Because I have no hx4700 (too expensive IMHO), I'm sorry I have no real chance to detect the misbehavior and so to be able to fix it.
Christoph
