Re: Opening the HP-71B Message #2 Posted by Vieira, Luiz C. (Brazil) on 18 Mar 2005, 3:34 p.m., in response to message #1 by John Pierce
Hi, John;
I openned mine once for checking purposes, and I found no problems separating half cases after removing (a bunch of) screws. I am not sure if there are screws under the rubber feet, but I think it's worth checking it, too.
On the other hand, I had some doubts about openning the HP75D because I felt some mechanical resistence on separating both halves after removing all screws (a bunch, too). After some reasoning, I forced it a bit and heard a loud 'cracking' sound. Fortunately it was super glue. I think that someone opened it and glued it back, but I am almost sure it was not any HP guy. As it has an AT&T label, I guess AT&T tech personal decided to glue the halves to avoid the computer to be inadvertently opened by other curious people... like me!
If you find yourself in trouble, I can take som epictures showing my HP71B opened.
Cheers.
Luiz (brazil)
