Re: Keyboard problem HP 41 Message #2 Posted by Raymond Del Tondo on 17 Mar 2005, 5:30 a.m., in response to message #1 by Peter
Hi Peter,
if you have some spares, have you tried replacing
the CPU pcb and of course the zebra stripe ?
I had a similar case some time ago, where the rightmost
column of keys didn't work partially.
Replacing the zebra stripe alone didin't help,
but replacing the CPU pcb was the solution.
It's not necessarily the solution for your case,
but it's an option to try;-)
Another possibility is corrosion and/or a broken
lane on the keyboard pcb.
Raymond
