Re: hp49g+ and SYSPRL Programming Message #2 Posted by Tim Wessman on 13 Mar 2005, 2:08 p.m., in response to message #1 by Tho Nilewi
you can easily use the built in plot overlay capabilities to put a normal cdf function on your bar graph. If you don't know how to do that, review the plotting part of the manual. To make it easier, download my statpack which includes a ton of stat stuff you will find usefull. You can use the NCDF function to do it. This is the same thing as doing a UTPN(x,x,x)-UTPN(x,x,x) if i remember correctly.
http://www.geocities.com/timwessman/39g2.html
TW
