Reduce a 49g+ to 4 stack? Message #1 Posted by Eric Lundgren on 12 Mar 2005, 6:12 p.m.
If the stack could be reduced (by a program or other?) to only four elements (ie 32sii xyzt), I suspect that the missed entry problem would be worked around..
Has anyone an idea to either limit the stack, or even create a font almost double the standard (8)? I just get too many errors as it is.
Also, does anyone else experience this:
In RPN mode, I enter:
number, left shift, square
and get this on the display:
number { sq() }
Its very frustrating, but only occasionally happens. Its as if it goes into eq. edit mode, or algebraic?
Best regards,
Eric
