Re: PRx on HP-41CX Message #4 Posted by Thomas Okken on 11 Feb 2005, 9:28 a.m., in response to message #1 by Michel Beaulieu
> Why is there tree stars *** print at the end of the line when executing PRx?
It always prints those stars when printing a result, as opposed to a number you just entered: in that case, it prints the command in that position.
For example, when the printer is set to TRACE, and the display mode is set to FIX 2, and you enter 2 ENTER 3 +, the print-out will look like this:
2.00 ENTER
3.00 +
5.00 ***
> Can i tell the calculator not to print these ***.
No, but you can work around it by using code like CLA, ARCL X, PRA (instead of CLA, fill the alpha register with 24 spaces if you want the number to be printed right-justified).
- Thomas
Edited: 11 Feb 2005, 10:14 a.m.
