Re: \->keytime (49g+) Message #3 Posted by James M. Prange on 2 Feb 2005, 3:13 a.m., in response to message #1 by Eric Lundgren
It seems to work as expected for me; the same on the 49g+ as on the 49G. But I've now noticed that values greater than 4096 are treated as 4096.
If you do 4096 \->KEYTIME and then KEYTIME\->, then it should return 4096, and a press of the same key again in less than 1/2 second should be ignored.
Of course, I don't recommend leaving it at 4096; probably something around 500 or less, depending on how fast you type. The 49G default of 1365 seems a bit high to me. Of course, if you don't get accidental duplication of keystrokes at all, you could just set it to 0.
Note that like all commands, these are case sensitive, so it should be \->KEYTIME, not \->keytime. Maybe use the RightShift CAT (over thr P key); both \->KEYTIME and KEYTIME\-> are in the catalogue.
