Re: HP41 CCD-Module Matrix files Message #4 Posted by Christoph Klug on 21 Jan 2005, 8:38 a.m., in response to message #3 by Mike (Stgt)
Dear Raymond, dear Mike,
changing XM file type by altering the file header register is easy possible with CCD-module commands PEEKB and POKEB.
But for creating a correct ASCII file format, also additional field distance bytes are needed, placed between the data bytes. Inserting this bytes in the correct order seems to be much more complex...
Up to now I only get wrong and uncomplete data, when reading them back from ILMass Storage Unit :-(
Yes the BC Module is running (Mike), but what about HC Module (raymond) ?
Best regards - Christoph
