Re: Disassembling dusty HP27S Message #2 Posted by Randy on 14 Jan 2005, 6:33 p.m., in response to message #1 by Erwin
Opening it will not get you any closer to the display, it's behind the logic board. The best way to clean is a couple of cycles through an ultrasonic cleaner. If that is not available, form a point on the end of the tube on an air blaster can. Stick the point in the case seam and blast away. Work from both sides and you should be able to get most of it out. It can be VERY stubborn.
Don't use any mechanical methods, you'll only scratch the inside of the lcd or polarizer, they are very soft materials.
