HP-35 accessories Message #1 Posted by NeilV on 12 Jan 2005, 6:38 p.m.
A co-worker cleaned out his parent’s basement and gave me an HP-35 calculator. This was the calculator I couldn’t afford as a student (72-75). Also a great addition to my slide rule collection considering this was the calculator that ended the slide rule era.
Thanks to the repair tips on this site I was able to find the hidden screws, open and remove the gunk from the on-off switch. I should have a replacement battery pack assembled later this evening.
My question is what accessories came with the calculator? I have a gray-blue box, manual and charger. Was the black (leather?) case a separate item? It doesn’t look like it would fit in the gray-blue box.
Thanks,
Neil
(Looks like I posted this question to the forum. 2X!! Mayber 3X is this attempt fails. Apologies. I hope someone with authority will delete it. Thanks.)
Edited: 12 Jan 2005, 6:40 p.m.
