Re: HP 71 - serial interface Message #3 Posted by Garth Wilson on 6 Jan 2005, 2:21 p.m., in response to message #2 by Emmanuel, France
Add to that the FSI164A from Firmware Specialists, Inc., which is virtually 100% compatible with the HP unit but came with two RS-232 channels and optionally up to 8, and also offered the option to go battery-powered. Mine is only two channels and not battery-powered. I've used it a lot with both the 41cx and the 71B. A scan of the manual (actually mine) is available on the HP-41 website.
There was a way to make a serial port on the 71 by soldering a couple of wires onto uncommitted I/O pins on the processor IC. (There would not be any line drivers or receivers though.) It doesn't seem to be in the book "Control the World With HP-IL", so maybe it was in one of the CHHU Chronicles. It would take me some digging to find it. I definitely would not risk damaging either of my 71's though when they both work 100% like new and there's no support for them anymore if I damage anything.
