Re: HP-67 Power Adapter replacement? Message #2 Posted by Jeff O. on 24 Nov 2004, 2:19 p.m., in response to message #1 by Derek
If you mean a source for the connector, the only source would be another power adapter. If you mean a source for a power adapter, try eBay, or place a want ad in the MoHPC classified section.
The problem you describe is quite common, and often repairable. It should not be necessary to destroy the plug. Try slicing the top of the plug off, cut, splice and solder the wires, then glue the top back on.
Good luck!
