Re: HP 71B-CMT 128K Module: which ports? Message #2 Posted by Garth Wilson on 21 Nov 2004, 8:26 p.m., in response to message #1 by Marcus von Cube
Card reader port is port 5, so you'll have 5.00 for the first 32KB, 5.01 for the next 32KB, then 5.02, and 5.03.
I got the same thing in 96KB. At the time, they were available up to 160KB, but memory was very expensive back then, and I had set a budget, and bought the biggest one it would allow for. Later I was able to get another 64KB for a front port. There was also a service that would hard-wire in 256KB if you'd send them the computer, so you could still have all your ports available for other uses.
