Re: Hp 17BII NEEDS URGENT HELP Message #2 Posted by Vieira, Luiz C. (Brazil) on 20 Nov 2004, 4:31 p.m., in response to message #1 by Will
Hi, Will;
I suspected that this is an italian message, so I used AltaVista Babel fish translator with the following sentece:
STAMPA DOPPIO SPAZIO
and it returned the following as the English equivalent:
Press double quantity space
In fact, this is one of the standard Italian messages available in the HP17BII (print with double space, or double space printing). I guess it is now locked in an internal loop with Italian language set as current language.
Have you tried to reset the calculator contents to the default? I mean, maybe after changing batteries with the HP12C (or any other calculator) you allowed a small quantity of electrostatic charge to interfere in the HP17BII circuits. You could try a brief short circuit (just a small touch) connecting the calculator's batteries contacts while the batteries are in. That would prevetn ESD to spread inside the calcualtor (as it seems this has already happened).
After that, try the calcualtor again and let us know.
Success.
Luiz (Brazil)
Edited: 21 Nov 2004, 11:17 a.m.
