Re: HP-34C repair Message #2 Posted by Vieira, Luiz C. (Brazil) on 18 Nov 2004, 1:27 a.m., in response to message #1 by Fred G
Hi;
I had two spices with corrosion in the battery connectors and the flex circuit (ribbon) that lead to corrode part of the power supply copper trails. Both units had soldered IC's and I mannaged to replace the ribbon for a piece of flat cable of the type used in computers.
In your case, being your HP34C a solderless-type Spice, I'd mannage to remove the corroded trails off the ribbon and clean (using chemicals) all of the oxidation left in the copper trails. Then I'd rebuild the removed trails with new, self adherent copper strips (there is a company that sales self adherent cooper foil you can "cut and past"; I don't remember the name) by using the remaining non-conductive part of the flex circuit.
I know it is a little bit vage, but when I face new situations I try to apply new solutions, if the known ones cannot fix the problem. I have in my mind what to do, and I have made some interesting repairs in "troubled" calculators. I wish I could help more.
Hope you succeed.
Luiz (Brazil)
