Re: HP9825 Calculator Message #2 Posted by Ron Ross on 17 Nov 2004, 10:24 a.m., in response to message #1 by Marie-Helene
You might also post in the classified section as this is the discussion board.
You might also consider broadening your search in both item ie Hp9830 or an Hp9820 if you are looking for nostaligia. If you are looking to replace a worn out machine you may find someone who can fix your old one also.
Ebay is another option. Good luck as I suspect that there is no low cost option.
