Re: Keyboard Layouts Message #4 Posted by Sam Hughes on 14 Nov 2004, 9:57 a.m., in response to message #2 by Raymond Del Tondo
You might notice that most younger people hold calculators in both hands and use their left-and-right thumbs (a behavior learned and coordination built from video game controllers). With this behavior, the left side would be the appropriate place for the operators, because when doing a series of operations, the left thumb would always press an operator or ENTER after each number entered, which would be the more-consistant behavior. The right hand would end up "covering" across the keyboard more, dominating the center column of keys more than the left hand, instead of having to move left and right to handle operators (as would happen of they were on the right side).
As a result, there would be space on the right side of the number pad for some keys, which might be shift keys, in which case it would be good to have the more-commonly used shifted functions on the left side of the keyboard (the left hand already being used for many operators, plus it being easier to use both hands instead of one). With the left hand being the main "operator" key, it would make sense to favor the left side for the most-common nonshifted operations as well (the right side of the row containing the ENTER key might be preferred to the keys just above the ENTER key, though).
Of course, this depends on how the person holds the calculator. I know somebody who held his TI-89 in both hands, with thumbs for the lower keys, but his index fingers, instead of sitting behind the keypad, curled up over the sides for pressing shift keys in the upper left and the arrow pad in the upper right.
