Suggestion to extend tests for Free42 Message #1 Posted by Namir on 11 Nov 2004, 1:48 p.m.
Hi Thomas,
I have a suggestion regarding HP42s tests (like X=0?, x>y? and so on). How about allowing the test to execute a subsequent "BLOCK" or statement that appears after the test, if the test is true, or skip that block if teh test is flase. The block is enclose by { and }. The open brace appears right after the test.
Here is an example:
2
STO 00
0.01
STO 01
RCL 00
ABS
1
X>Y?
RCL 00
STO* 01
<more commands here>
If the test X>Y? is true then the processor executes the block of commands (RCL 00 and STO* 01 that are in the block that appears after the test. If the tested condition is false the processor skips the block altogether. Of course a block MAY contain other tests with their own blocks, so there should be a counter to detect the appropriate }.
Namir
