Not quite what I was asking Message #3 Posted by Gene on 4 Nov 2004, 4:00 p.m., in response to message #2 by Richard Garner
I know that using LB of the PPC Rom to Load 027 019 will give a synthetic program line of E3, without the leading 1 as in 1 E3.
I'm looking for a way to key that in directly using the extended XEQ of the CCD rom.
Appears as if that doesn't work.
When I press XEQ ENTER and then type in 027 019 in the prompts, I get an "E" by itself on a line and then text garbage in the next program line.
I read Mike's comment about using the Zenrom to do this, but it would be nice if I didn't have to use an entire 4K of the NoVRAM module just to get the short-form exponent entry capability.
Gene
