HP49+ Connectivity kit Message #2 Posted by Francesc Casanellas on 3 Nov 2004, 3:19 p.m., in response to message #1 by John Carter
I recommend you to follow these steps:
1. Turn on the calculator
2. Start the connectivity software.
3. Turn on the calculator.
4. WAIT for a warning sound
5. In "Connect using"... select HP49G+
6. Go to File/Connect
7. You are prompted to press the right shift (red) key and THEN (not at the same time) the right arrow (in the group of the 4 round keys).
8. Click on OK
If your USB port is right this should work
Edited: 3 Nov 2004, 3:22 p.m.
