Re: want something ......... Message #3 Posted by Vieira, Luiz C. (Brazil) on 4 Nov 2004, 6:09 a.m., in response to message #1 by Cannondale
Hi;
I'd like to ask about one thing. The HP15C already has matrix operations available for use (inversion, transposition, etc.) and maybe one of the things that you want is actually a description of these matrix operations. You can see the [f][MATRIX] over the [EEX] key) and there is a list of available MATRIX operations in the back of the calculator. If yours is weared out and hard to read, try this:
There's a few information here that might be of some use for you, as well. Maybe your needs can be satisfied with the existing HP15C resources.
If what you need is actually general programming, then Karl's suggestion is the best choice.
Let us know.
Cheers.
Luiz (Brazil)
