Re: HP41CX Copper Interconnectors Message #7 Posted by J.W. on 27 Oct 2004, 11:05 a.m., in response to message #3 by Randy
I checked on the Museum web site as Raymond suggested and found this by Stefan Vorkoetter (under the Museum Home Page under Repairs and Batteries - Repairing the HP41CX):
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/articles.cgi?read=2
and I quote from this artcle by Stefan:
"Notice the two rows of contact fingers between the top screw posts, and the two long rows and one short row between the bottom screw posts. (I think the 41C and 41CV don't have the short interconnect.)"
and
"On my HP-41CX, one of the three flexible CPU board to keyboard interconnects was missing. It was most likely lost during a previous repair attempt (the rubber feet were also missing). I decided to do away with the interconnects entirely, and hardwire the CPU board to the keyboard. This has the advantage that the connection will no longer rely on the integrity of the bottom screw posts."
and
"Next, cut 4 pieces of wire of the appropriate length to reach from the middle row of contacts on the keyboard to the corresponding contacts on the CPU board. Strip 1/8" insulation from each end, and solder them in place as shown."
This indicates on the HP41CX model that Stefan had, that there were 3 copper interconnectors between the screw posts - 2 long and 1 short(middle) - which he replaced with 16 + 16 + 4 soldered wire connections.
On the second of the pictures in this article by Stefan you can just make out the row of 4 extra contacts (LHS)in between the 2 rows of 16 contacts near the bottom screw posts.
