Kenko FX-82LB breaks $1 price barrier Message #1 Posted by Norris on 1 Oct 2004, 6:02 p.m.
The Kenko FX-82LB scientific calculator is now being distributed in California and other parts of the southwestern US. It is not innovative in terms of features or quality, but it may be noteworthy for its price: 99¢. Check your local 99¢ Only store; they've got lots.
So how much scientific calculator can you get for less than one dollar?
Most of the expected functionality is there: four levels of parentheses, trig and hyperbolic functions, deg/rad/grad modes, logs, factorial, binary/octal/hex modes, complex number operations, statistics, random number generator, DEG<>DMS, rect<>polar, etc.
Complex numbers are handled in CPLX mode, using an "a" and "b" key for real and imaginary parts. So adding (6 + 3i) and (4 + 2i) goes like this: 6 a 3 b + 4 a 2 b = 10 (real part). You then hit the "b" key to get 5 (imaginary part).
Uses 10 digits plus a 2-digit exponent. Only one storage register. No programmability (although the = key has a "constant" function).
Limitations: no combinations and permutations, no way to seed the random number generator, STAT mode can only handle one variable -- not (x,y) values, no linear regression, no fraction mode (although there is a big "FRACTION" label above the display).
Construction feels, well, cheap. Keys are rubber; the function keys are so small that it is hard to press them accurately. No case is provided, but there is a hard cover that is attached to the top of the calculator by a hinge. The cover has 3 modes: (1) it fastens over the keyboard when closed, (2) it swings out of the way behind the calculator to serve as a stand, and (3) it falls off sometimes.
The manual is 32 small pages. The documentation is sparse, poorly translated, and riddled with typos, but mostly comprehensible.
The 1-line display is surprisingly good (at least to a heavy HP 33S user). Big clear digits and legible decimal point, which is offset downward. No commas.
The packaging makes a number of questionable claims, with a few outright lies:
"Scientific" (OK, but this is accompanied by a picture of a graph, which seems misleading in a non-graphing model)
"229 functions" (I haven't tried to count them, but this seems awfully high)
"2-Line Big Display" (nope, only 1 line)
"S-V.P.A.M." (I don't remember what this stands for, but I suspect that Casio's lawyers would not approve)
"Plastic Keys" (nope, rubber)
But I don't want to end this review on a negative note. The Kenko FX-82LB is, to the best of my knowledge, the most powerful calculator that you can get today in the sub-$1.00 price range. It's worth every penny.
Edited: 1 Oct 2004, 7:45 p.m. after one or more responses were posted
