A personal observation (long) Message #2 Posted by DavidY on 24 Sept 2004, 6:26 p.m., in response to message #1 by Juergen Rodenkirchen
The answer is yes and no...
Clonix and NoVRAM are hardware emulators of 41C ROM modules using a microcontroller with internal and external memory fitted to the footprint of a ROM module.
Clonix is effectively ROM only. While memory is eprom the module can only be programmed EXTERNALLY with a PC attached programmer. This means any mcode (or FOCAL) program development would be done on a PC based emulator and compiled-to-Rom image code then would be burnt to the Clonix module. For most 41 users this module is best for providing the chance to use images of ROM modules which are unobtainable now. Plus because it allows for 24K+ of space it also allows 41C and/or CV machines to fit multiple "ROM modules" into the physical space of one module even if the images take up multiple "ROM addresses". This is because so-called "system" modules (memory, xmemory,etc.) do not take up module addresses (slot 8-f).
NoVRAM can be though of as a specialized version of Clonix designed to emulate a VERY specialized module from a 41 developer: the HePax. This module was quite probably the hight of development for the 41. It was a module contain ROM and RAM, with the RAM mapped into the ROM address space (8-f). The Rom code portion to care of mapping the Ram, provided initializing and loading code into ram, creating a standard address structure,etc. As initially set up NoVRAM has ram configured for use similar in concept to the 41's extended memory. The bonus is that HePax stores programs such that they appear in a directory as if they are a ROM module of user code. NoVRAM also has some free eprom space in which rom module images can be programmed. But, again, the eprom space holding the 4 pages of HePax code and extra pages are effectively only programmable externally by way of a PC.
Because of the adoption of a standard way of using an unused CPU opcode to access ROM space for reading or writing and because the Hepax provides a way to "map out" ram from HePax use; blocks of ram in the NoVRAM can be used to directly develop mcode with a 41. In fact, the HePax includes a hex editor and other routines to facilitate this. Also if one knows what to do the Hepax Rom code can be deleted and/or overwritten with other rom images leaving the full amount of ram available for use for programming with code like the David Assembler (I'm NOT that David, by the way) or ZenRom.
MLDL is, I believe, designed to fit a Card Reader sized case. Reading the documentation it appears to be designed to provide maximum space for module images, to allow for bank switching of multiple pages (read entire ROM address spaces), and potentially provide for IO mapping into ROM address space to facilitate direct 41 to PC (or other device) interconnection. The MLDL's design allows for programming directly from a 41 or indirectly from a PC.
My personal view is that (1) both designs Clonix/NoVRAM and MLDL are amazing developments. The work done is excellent, and (2) the impact the 41 from opposite directions: the MLDL is a modern updating of those devices designed during the 41's "active" life to provide users with the ability to create their own ROM code but with many more pluses. The Clonix/NoVRAM comes from the path of providing those who still use the 41 with the ability to "use" those ROM modules which we never could get and which are impossible to find now.
Think Clonix/NoVRAM for day-to-day transparent use and MLDL for development and/or big time special use. They all complement each other and don't compete.
Disclaimer: I don't have either Clonix or NoVRAM (yet!) and of course the MLDL isn't yet "released for production" so all this comes from their available documentation and my (small) knowledge/practice of 41 mcode development on 41 emulators (thank you "TOS" webmaster) so please take the above as a personal and in no way official explaination. I am no way in a league with the very talented gentlemen who actually developed these amazing devices. When you consider the 41 is 20+ years old the phrase "labor of love" in no way approaches their dedication.
