Re: HP 15-C Help Message #2 Posted by Vieira, Luiz C. (Brazil) on 21 Sept 2004, 12:28 a.m., in response to message #1 by Chuck
Hi, Chuck;
try this:
with the calculator off, press and hold the [.] key;
while holding [.] down, turn the calculator to on;
release the [.] key.
Anytime you want to toggle the radix mark (from dot to comma and converselly) you can follow this keystroke sequence.
Cheers.
Luiz (Brazil)
Edited: 21 Sept 2004, 1:37 a.m.
