Re: Plotting Hurricane Ivan Message #3 Posted by Dave Shaffer on 11 Sept 2004, 4:52 p.m., in response to message #1 by deleted
Jim,
Plot the lat/lon coordinates for each time point that you have. The result will be the trajectory of the hurricane as a function of time. If you start with a map having lat/lon on it, you can actually see what islands are getting the brunt of Ivan.
Or, you can look at what these guys have:
http://www.intellicast.com/Local/USNationalWide.asp?loc=usa&seg=StormCenter&prodgrp=TrackingCharts&product=HurTrack2&prodnav=none&pid=none
I hope the URL isn't too long for your viewer. If so, then just go to www.intellicast.com (their home page), and the hurricane track is on the right-hand side. If you click that image, you will be taken to the address above.
As Karl points out, the ultimate track of Ivan depends not on mathematical calculations, but on the driving forces that make the weather happen (only somewhat predictable!).
