HP-97 free transistor Message #1 Posted by Michel on 26 Aug 2004, 10:42 p.m.
Hi, well, i'm a little bit embarassed of the situation... I opened my HP-97 to repair the gummy wheel problem but when i finish the job, the calculator didn't work at all!!!
I open it again and i fond a completely free loose transistor in in back case!!!
The problem is that i don't know where is that transistor is fiting nor where to solder it!
- on the keyboard board i have 3 transistors
- on the card reader reader, i have one transistor
- on the back of the printer board i found one transistor
- on the main board i found 4 transistors.
The number on the transistors is : M624 3-393
I found that number on other transistor on the calculator so it don't help me...
I look at some pictures but i seems that there is some PCB revision because i have some transistors on the main board that are not on th pictures i saw... ;-(
WHERE DOES IT GOES???
Edited: 26 Aug 2004, 11:02 p.m.
