Re: woodstock/97 plastic keyboard conditioning Message #3 Posted by Ronald on 24 Aug 2004, 7:41 a.m., in response to message #1 by andy
After disassembling I let the keys "swim" for 1 day in a chlorine solution (the one you use to clen the toilet). This makes them quite well back to their original color.
After that I brush the housing and the key's with a light abbrasive stuff (white, chalklike) you use for cleaning the sink. This gives back the normal "glossy" appearance and lightens the yellowed signs. But use this carefull, you do not want to "clean" the letters.
Succes
Ronald
