Re: 9825 Message #4 Posted by David Ramsey on 15 Aug 2004, 1:09 a.m., in response to message #3 by marais
Well, I've never actually heard of a "9125", but the problems tape drives on the desktop HP calcs have are pretty much the same as the problems the handhelds have: dirty heads and disintegrating rubber on the drive wheels.
The larger size of the desktop machines makes them easier to work on.
I replaced the rubber on the drive wheel of my 9825 with heat-shrink tubing. It's true! Slide large tube over the cleaned drive wheel, heat shrink, trim with razor blade.
Cleaning the tape head can be done with Q-tips and alcohol.
