Re: surveying calculator Message #7 Posted by Norris on 7 Aug 2004, 3:52 p.m., in response to message #6 by db(martinez,california)
As indicated by db, Software by D'Zign currently markets surveying software for the HP49G+ (not clear if it runs on the 48GII). Their software is available at:
http://www.calcpro.com
Another company markets a package called SurveyWorks, which is apparently compatible with both the 48GII and 49G+. See:
http://www.levelworks.net/surveyworks.htm
And yet another company markets a package called Survey Stakeout, which is apparently compatible with the 48 and 49 series. This company also markets a version for the HP-33S; the 33S version is specifically designed for use on the LSIT and PLS exams, where 48s and 49s are not allowed. See:
http://www.hp33ssurveyor.com
Several companies that historically marketed surveying cards for the HP48GX, such as TDS, SMI, and RAMSS, are apparently not supporting the 48GII or 49G+. Their software cards may still be available, but they will only work with the discontinued 48GX.
Edited: 7 Aug 2004, 4:09 p.m.
