Re: 17bii programming Message #2 Posted by Vieira, Luiz C. (Brazil) on 1 Aug 2004, 11:56 a.m., in response to message #1 by hugh steers
Hi, Hugh;
what I know that is possible (although it is not what you ask for, but may help as well) is saving the results from the "other formula" in a user variable and call this variable contents from another formula.
If you update the "common procedure" before using its results then it works the way I see it, but I don't know if the SOLVE menu will "open" menu keys for both formulas (variables) at the same time. Also, if your experiment lead you to this sort of reasoning, it is more likely that you already know about what I wrote here... ;-)
Not that much for an answer... Should I count it as a 1¢ contribution?
Cheers.
Luiz
Edited: 1 Aug 2004, 6:58 p.m.
