Re: Writing notes into HP49G+ Message #2 Posted by Eddie Shore on 16 June 2004, 3:34 p.m., in response to message #1 by Andrew
So far the only way I know is to create a string variable with your text and store the text you write. While creating your notes, you can press TOOL access STYLE [TOOL] [NEXT] [NEXT] |Style| to highlight, bold, itlicize (sp?), or underline text. Use the [LS] [BEGIN], [LS] [END] to select your text.
hpcalc.org may have text writing programs for the HP49G+.
Good luck,
Eddie
