Re: HP 41C Battery Contacts Repairable? Message #5 Posted by Randy on 13 June 2004, 9:04 p.m., in response to message #4 by Marx Pio
The best way to repair 41 battery contacts is with 1/8" (3 mm) brass channel that is available in hobby stores. Cut a 1/4" (6mm) long piece for each terminal and solder over nasty, rotted battery connection points. Repaired in this way, the connector will outlast the remainder of the calculator.
If the connector is really rotted, you'll need to scrape the film off where the long flat sides of the brass meets the connector to be able to solder it in place. You must use a good, temperature controlled soldering iron or you'll destroy the connector.
