Problem with program conversion? Message #1 Posted by Iqbal on 3 June 2004, 9:11 p.m.
I converted all my GX programs to my 49G+. The problem is when the result is displayed, the last prompt also remains on the display. Is there a way to get rid of this last prompt and only have the result displayed?
Check out this example. The program uses Trapezoidal rule to calculate the area.
« 0 0 0  N D L
« 0 ¨LIST 'L' STO
"Strip Width?"
PROMPT 'D' STO
"No of Offsets?"
PROMPT 'N' STO 1
STD N
FOR i "Offset "
i + PROMPT L + 'L'
STO
NEXT 4 FIX L
HEAD L TAIL 'L' STO
L REVLIST 'L' STO L
HEAD + L TAIL
IF N 3 SAME
THEN HEAD
ELSE …LIST
END 2 * + 2 / D
* 1 FIX "m" + ² +
" Area = " SWAP +
CLLCD 3 DISP 7
FREEZE 4 FIX
When the area is displayed, the last prompt [the 3rd if there are 3 offsets] is also displayed. Only solution is diosplayed in GX
