Re: HP49G+ to HP48GII Message #3 Posted by Vieira, Luiz C. (Brazil) on 27 May 2004, 8:15 p.m., in response to message #1 by Rick
HI;
I guess that using ASCII mode without translation will cause any program to be transfered without troubles. I remember that I hhd problems tranfering programs from one HP48G to an HP48S whan in binary mode, but in ASCII there was no problem. And the exclusive HP48G commands were kept as unchanged names, meaning they would be placed in the stack instead of being executed (and generate some error later). If you keep binary mode, some internal calls to addresses not defined may appear.
I guess thatīs the only problem: using binary mode. BUT if you are sure that your HP49G program has only valid commands for the HP48, I see no trouble.
Cheers.
Luiz (Brazil)
