And, if you want only... Message #3 Posted by Vieira, Luiz C. (Brazil) on 27 May 2004, 2:32 a.m., in response to message #1 by Mike
... changing the number of digits after the separator (i.e., keeping current format), [DSP]n will do as a stand-alone operation. OR, if you want changing only the number format (i.e., keeping current number of digits after the separator), [IFX], [SCI] or [ENG] will do, as stand-alone keystrokes.
I just wanted to add to Randy's explanation that the key sequences can be used separately.
Success!
Luiz (Brazil)
Edited: 27 May 2004, 2:32 a.m.
