Re: voyager keyboards Message #2 Posted by Nelson M. Sicuro (Brazil) on 20 May 2004, 12:39 p.m., in response to message #1 by hugh steers
For my experiences with voyagers:
1) gold-plated dual face PCB with circles and a dot inside for each key
2) steel domes (strips with 5 connected in line, 4 strips on the left half, 4 on the right half - I don't know if they are plated inside)
3) adhesive tape
4) thin rubber layer (removable)
5) articulated keys with a center "pin" that presses the rubber/steel dome
6) plastic case
I noticed when the keyboard is very used the rubber layer develop holes when the key "pins" touch it, creating a "lower" and a little loose key.
I can provide high-resolution scans from my 15C and 11C if you want.
This information is from the mid-aged voyagers, with a single PCB with the keyboards and chips, serial <= 27xxxXxxxxx.
Best regards,
Nelson
Edited: 20 May 2004, 12:41 p.m.
