Re: +/- key on RPN calcs Message #2 Posted by Dave Shaffer on 18 May 2004, 4:11 p.m., in response to message #1 by Bill P
From the beginning (the HP 35) there was the "CH S" (change sign) key - although its operation depended on what keys you had most recently hit. From the Museum description of the HP 35:
"The HP-35 allowed the user to press the CHS sign before or during number entry. If a number was in the display as a result of something other than digit entry, pressing CHS negated it, but if the CHS key was then followed by a digit, the calculator assumed the CHS was actually meant for the following entry. Thus the previous number displayed was pushed onto the stack without the (already displayed) sign change. This feature could be confusing and later models required the CHS key to be pressed after the first digit of a number."
