Re: 15C Display bleeding Message #4 Posted by Randy Sloyer on 18 May 2004, 8:35 p.m., in response to message #3 by Marx Pio
Pio,
Open the 15C. If it is a one chip version unit, the LCD from the 12C will work.
I do not know which version 11C you have as I have seen only a few Brazilian units. I suspect it is a two chip model which will work in a three chip 15C.
You can refer to this thread for more info on the LCD differences: http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv013.cgi?read=46995
I hope that helps.
Edited: 18 May 2004, 8:37 p.m.
