Re: 15C backplate lifting up Message #3 Posted by bill platt on 15 May 2004, 10:02 a.m., in response to message #1 by Mike Head
Hi Mike, and Hi Randy (tnx for finding my old thread w/your answers!)
Yes, I successfully repaired it---but there are some things that I did wrong:
1. Do not use acetone (what was I thinking!) for the glue removal--the case is styrene, which dissolves in acetone. Use denatured alchohol and be patient.
2. In "peeling" the aluminum up, I created ridges in the aluminum, which are still visible---I was a bit impatient, and I used a very thin (but not thin enough!) knife as a wedge--driving through the crack as I wet it with alchohol. Be very patient with the peeling up part---don't peel! Let it soak for a loooong time---maybe randy can weigh in on this.
3. I used the 3m "carpet tape" to put everything back on--and that worked well---except I lost a couple of feet---because the residue of the old glue "slimed" in contact with the 3m adhesive---and so the feet slid off. The rubber feet which I had thoroughly cleaned of residue stayed on.
4. I have some photos of this calc around--email me and I'll send them back at you.
find my e-mail address by going to my website:
http://plattdesign.net
Good luck!
Bill Platt
Edited: 15 May 2004, 10:05 a.m.
