Re: problems with photosmart c200 Message #4 Posted by Richard Garner on 15 May 2004, 2:25 p.m., in response to message #3 by calin b
Which COM port are you using and are you using an internal dial-up modem? Most internal modems are set to use COM2 and will also block COM4. It may be in conflict with you modem. Try moving it to COM1 if it is not already there and check all of the port settings in Windows as well as the software you are using.
