STILL MORE Info. - Intriguing Message #10 Posted by Wayne Stephens on 12 May 2004, 7:49 p.m., in response to message #8 by Wayne Stephens
When I got home from work this evening I tried Gene's recommended calculation on my "new" 33S (purchased from the "second" batch of Walmart.com calcs, about three weeks ago).
With this calculator I get the "Divide by 0" Error. The first x<>Y "swap" entry results in 24 followed by "divided by" in the top row, and 0 in the bottom row, which certainly will result in a "Divide by Zero" error when one pushes the "Enter/=" key. The question is, why is my "newer" 33S treating the "stack" differently from my "original" 33S.
Obviously there is some difference between the "first run" and "second run" of these calculators; or at any rate there are two different "versions" out there.
By the way, I would never have found this little glitch in a million years on my own, because I stubbornly and irrationally refuse to recognize the legitimacy of "algebraic entry" calculators. I am willing to admit they EXIST, I'm just not willing to USE one of the wretched things. Before today, I literally had never put either of my 33S calcs into ALG mode.
I have not yet found any differences between the two when operating in RPN mode, but that doesn't mean they are not there. Thanks A LOT, Gene, now I'm going to be up all night doing "side by side" calculations on these two machines.
Take care.
Wayne.
