Re: Woodstock capacitor values? Message #6 Posted by Tony Duell on 10 May 2004, 2:37 p.m., in response to message #5 by John Garza
Be careful. If that's the black diode (all the others being white with coloured bands), it's a zener used as part of the PSU regulation circuitry. I don't have the schematics in front of me, but basically, one transistor is an oscillator, the other removes the base voltage from it if the output voltage gets too high. Now, Vss is around 6.2V, you want about 0.6V be-drop across the base-emitter junction of the regulator transistor, so I guess it's a 5.V zener. But I don't know. What I do know is that it's not just a normal diode!
