Re: HP-67 batteries Message #3 Posted by Tom (UK) on 5 May 2004, 12:55 p.m., in response to message #2 by Jeff
If you are worried about 4.5V being more than the 3.6V then put a diode in series with the batteries as this will drop the voltage by about 0.7V (for a silicon diode). You must use a high capacity diode (5A safe?) for driving the peak load when the card read motor is on.
Please note that this will not stop you connecting the battery the wrong way round (unless you solder it to the calculator) as the diode doesn't know what lead you just connected the battery to!
Perhaps you could make up a battery pack with a diode and some flying leads ending in small crocodile clips - suitably marked so you get the polarity right!
