Re: HP 82106A memory module Message #2 Posted by Raymond Del Tondo on 27 Apr 2004, 11:05 a.m., in response to message #1 by cesar
Set SIZE 000, then switch to PRGM mode, note the amout of registers.
Turn off the calc, insert the memory module, switch on, then go to PRGM mode, compare the amount of REGisters to the first one. If the difference is about +/- 64 registers, the module is working;-)
Raymond
